Ga door naar hoofdinhoud
Help
Nikon Coolpix P100 Display Screen Replacement
Verwarrende Tekst
Verwarrende Tekst
Een deel van de tekst in deze handleiding is verwarrend, dubbelop of naast de kwestie. Bewerk de tekst en maak hem duidelijker!
Knip- en plakwerk
Knip- en plakwerk
De stappen in deze handleiding moet worden opgesplitst in een reeks van vereiste handleidingen.
Stappen inkorten
Stappen inkorten
Deze handleiding heeft onnodige stappen. Kort ze in om beknopter te kunnen zijn!
This guide will help users replace specific components of the Nikon Coolpix P100.
  • Auteur: Rikki Brown
  • Geschatte tijd: 15 - 30 minuten
  • Moeilijkheid: Gemiddeld
Stap 1 Display Screen  ¶
Nikon Coolpix P100. Nikon Coolpix P100.
  • Nikon Coolpix P100.
Stap 2  ¶
Set the camera upside down so that the side with the serial number is face up. Pull back the display panel.Orient the panel so that you are able to view the back of it. Pull back the display panel.Orient the panel so that you are able to view the back of it.
Stap 2  ¶
  • Set the camera upside down so that the side with the serial number is face up.
  • Pull back the display panel.Orient the panel so that you are able to view the back of it.
Stap 3  ¶
Using a Phillips head screwdriver unscrew the two screws closest to the piece connecting the panel to the camera. Using a Phillips head screwdriver unscrew the two screws closest to the piece connecting the panel to the camera.
Stap 3  ¶
  • Using a Phillips head screwdriver unscrew the two screws closest to the piece connecting the panel to the camera.
Stap 4  ¶
Remove the cover that was unscrewed in the last step.
Stap 4  ¶
  • Remove the cover that was unscrewed in the last step.
Stap 5  ¶
Using a Phillips head screwdriver  remove the remaining four screws on the outermost corners of the panel.
Stap 5  ¶
  • Using a Phillips head screwdriver remove the remaining four screws on the outermost corners of the panel.
Stap 6  ¶
Use a plastic opening tool to pry open the back panel display screen. Use a plastic opening tool to pry open the back panel display screen. Use a plastic opening tool to pry open the back panel display screen.
Stap 6  ¶
  • Use a plastic opening tool to pry open the back panel display screen.
Stap 7  ¶
Carefully unhook the ribbon that attaches the panel to the camera. Remove the top black cover of the panel. Disassembling Nikon Coolpix P100 Ribbon Cable Carefully unhook the ribbon that attaches the panel to the camera. Remove the top black cover of the panel. Disassembling Nikon Coolpix P100 Ribbon Cable Carefully unhook the ribbon that attaches the panel to the camera. Remove the top black cover of the panel. Disassembling Nikon Coolpix P100 Ribbon Cable
Stap 7  ¶
Stap 8  ¶
Remove the two screws on the panel that are closest to the ribbon cable.
Stap 8  ¶
  • Remove the two screws on the panel that are closest to the ribbon cable.
Stap 9  ¶
Remove the other two screws on the opposite side of the panel.
Stap 9  ¶
  • Remove the other two screws on the opposite side of the panel.
Stap 10  ¶
Separate the metal portion of the screen from the plastic portion. Separate the metal portion of the screen from the plastic portion.
Stap 10  ¶
  • Separate the metal portion of the screen from the plastic portion.
Stap 11  ¶
Carefully remove the ribbon connector cable from the metal portion of the display.
Stap 11  ¶
  • Carefully remove the ribbon connector cable from the metal portion of the display.
Stap 12  ¶
Now you have successfully removed the display panel.
Stap 12  ¶
  • Now you have successfully removed the display panel.
