Ga door naar hoofdinhoud
Help
Nikon Coolpix P100 Motherboard
Grammaticapolitie
Grammaticapolitie
Laat je innerlijke leraar Nederlands vrij en help om de grammatica van deze handleiding te verbeteren!
Verwarrende Tekst
Verwarrende Tekst
Een deel van de tekst in deze handleiding is verwarrend, dubbelop of naast de kwestie. Bewerk de tekst en maak hem duidelijker!
Knip- en plakwerk
Knip- en plakwerk
De stappen in deze handleiding moet worden opgesplitst in een reeks van vereiste handleidingen.
Betere introductie
Betere introductie
Verbeter deze handleiding door het afmaken of herzien van de introductie.
This guide will show you how to access the Nikon Coolpix P100 motherboard.
Stap 1 Motherboard  ¶
Turn the front of the camera toward you.
  • Turn the front of the camera toward you.
Stap 2  ¶
On the left side of the camera, use a Phillips #00 Precision Screwdriver to remove the two screws. On the left side of the camera, use a Phillips #00 Precision Screwdriver to remove the two screws. On the left side of the camera, use a Phillips #00 Precision Screwdriver to remove the two screws.
Stap 2  ¶
  • On the left side of the camera, use a Phillips #00 Precision Screwdriver to remove the two screws.
Stap 3  ¶
On the right side of the camera, remove the first visible screw.
Stap 3  ¶
  • On the right side of the camera, remove the first visible screw.
Stap 4  ¶
Lift the HDMI and A/V OUT cover to access the hidden screw and remove.
Stap 4  ¶
  • Lift the HDMI and A/V OUT cover to access the hidden screw and remove.
Stap 5  ¶
Flip the camera upside down and remove the seven marked screws.
Stap 5  ¶
  • Flip the camera upside down and remove the seven marked screws.
Stap 6  ¶
Remove the two screws hidden underneath the display panel. Remove the two screws hidden underneath the display panel.
Stap 6  ¶
  • Remove the two screws hidden underneath the display panel.
Stap 7  ¶
Use a plastic opening tool to gently loosen up the sides of the camera. Use a plastic opening tool to gently loosen up the sides of the camera. Use a plastic opening tool to gently loosen up the sides of the camera.
Stap 7  ¶
  • Use a plastic opening tool to gently loosen up the sides of the camera.
Stap 8  ¶
Carefully open the camera. There are two ribbon cables when opening the camera. Make sure to properly detach them before proceeding.
Stap 8  ¶
  • Carefully open the camera.
  • There are two ribbon cables when opening the camera. Make sure to properly detach them before proceeding.
Stap 9  ¶
Now you have partial access to the camera's motherboard.
Stap 9  ¶
  • Now you have partial access to the camera's motherboard.
  • Remove the five indicated screws that are attached to the metal plate.
Stap 10  ¶
Remove the hidden top screw that is attached to the metal plate.
Stap 10  ¶
  • Remove the hidden top screw that is attached to the metal plate.
Stap 11  ¶
Use a plastic opening tool to carefully loosen the metal plate. Remove the panel to access the camera's motherboard. Remove the panel to access the camera's motherboard.
Stap 11  ¶
  • Use a plastic opening tool to carefully loosen the metal plate.
  • Remove the panel to access the camera's motherboard.
Stap 12  ¶
Now you have access to the camera's motherboard
Stap 12  ¶
  • Now you have access to the camera's motherboard
