Ga door naar hoofdinhoud
Help
PowerBook G4 Aluminum 15" 1.5-1.67 GHz Speakers Replacement
  • Auteur: iRobot
  • Moeilijkheid: Moeilijk
Restore sound to your laptop by replacing the speakers.
Stap 1 Speakers  ¶
Remove the two 3 mm black Phillips screws from the left ambient light sensor board.
Stap 1 Speakers  ¶
  • Remove the two 3 mm black Phillips screws from the left ambient light sensor board.
  • Lift the left ambient light sensor board out of the computer, removing tape as necessary.
Stap 2  ¶
Deroute the Bluetooth and RJ-11 cables from around the left side of the speaker.
Stap 2  ¶
  • Deroute the Bluetooth and RJ-11 cables from around the left side of the speaker.
Stap 3  ¶
Disconnect the speaker cable from the DC/Sound card.
Stap 3  ¶
  • Disconnect the speaker cable from the DC/Sound card.
Stap 4  ¶
Remove the 4 mm hex nut from below the left speaker.
Stap 4  ¶
  • Remove the 4 mm hex nut from below the left speaker.
  • Remove the 3 mm black Phillips screw from bottom left corner of the speaker assembly, to the left of the battery compartment.
Stap 5  ¶
Lift the speaker assembly (including the right speaker) out of the computer.
Stap 5  ¶
  • Lift the speaker assembly (including the right speaker) out of the computer.
