Help
Disassembling Polaroid a520 Battery cover
Stap gemist
Stap gemist
Oeps! Deze handleiding mist nu een paar belangrijke stappen.
Mislukte opmaak
Mislukte opmaak
Deze handleiding heeft een betere opmaak nodig. Help mee door het corrigeren van de opmaak of door aantekeningen te maken.
Replacing the spring loaded battery cover
  • Auteur: Dani
  • Geschatte tijd: 10 minuten
  • Moeilijkheid: Gemiddeld
How to replace the spring loaded battery cover or the spring.
Stap 1 Disassembling Polaroid a520 Battery cover  ¶
Unscrew the four (6mm) screws from the inner casing.
  • Unscrew the four (6mm) screws from the inner casing.
Stap 2  ¶
Pull the inner casing off.
Stap 2  ¶
  • Pull the inner casing off.
  • If all the screws are out the casing will come off easily. If it doesn't check to make sure all the screws are completely out of the plastic.
Stap 3  ¶
Locate the push pin near the bottom of the camera.
Stap 3  ¶
  • Locate the push pin near the bottom of the camera.
Stap 4  ¶
Use the spudger to push the push-pin partly through.
Stap 4  ¶
  • Use the spudger to push the push-pin partly through.
Stap 5  ¶
From the other side pull the pin all the way out. The battery cover will fall off.
Stap 5  ¶
  • From the other side pull the pin all the way out. The battery cover will fall off.
Stap 6  ¶
The spring can just be pulled out of the holes.
Stap 6  ¶
  • The spring can just be pulled out of the holes.
