Ga door naar hoofdinhoud
Help
Xbox 360 GPU Heat Sink Replacement
GPU heat sink replacement.
  • Auteur: Walter Galan
  • Geschatte tijd: 1 - 3 uren
  • Moeilijkheid: Moeilijk
Use this guide to remove your Xbox 360's GPU heat sink. Before reinstalling the heat sink, be sure to apply a new layer of thermal paste.
Secties
Stap 1 GPU Heat Sink  ¶
Insert the tip of a small flathead screwdriver between the X clamp and its retaining post on the heat sink.
  • Insert the tip of a small flathead screwdriver between the X clamp and its retaining post on the heat sink.
  • Pry the X clamp away from its retaining post until it is lifted above the small groove cut into the retaining post.
Stap 2  ¶
Insert your screwdriver parallel to the motherboard between the X clamp and its retaining post. Twist the screwdriver to fully release the X clamp from its retaining post.
Stap 2  ¶
  • Insert your screwdriver parallel to the motherboard between the X clamp and its retaining post.
  • Twist the screwdriver to fully release the X clamp from its retaining post.
  • Repeat this process for all four corners of the X clamp.
  • When removing the last corner of the X clamp and holding the motherboard upside down, be sure to catch the GPU heat sink to avoid damage from it falling.
Stap 3  ¶
To reinstall the X clamp, first start by attaching two corners to the posts on the heat sink.
Stap 3  ¶
  • To reinstall the X clamp, first start by attaching two corners to the posts on the heat sink.
  • While holding the third arm of the X clamp down against the post attached to the heat sink, use a small flathead screwdriver to pry the X clamp away from the heat sink post.
  • As you pry, press down on the arm of the X clamp until you "walk" it down into the retaining groove cut into the post attached to the heat sink.
  • Repeat this process for the fourth arm of the X clamp.
Stap 4  ¶
Remove the GPU heat sink.
Stap 4  ¶
  • Remove the GPU heat sink.
  • Before reinstalling the GPU heat sink, be sure to apply a new layer of thermal paste.
  • If you need to mount the heat sink back onto the motherboard, we have a thermal paste guide that makes replacing the thermal compound easy.
