Ga door naar hoofdinhoud
Help
Blu L120 Battery Replacement
Betere introductie
Betere introductie
Verbeter deze handleiding door het afmaken of herzien van de introductie.
Replace the battery in your Blu L120.
  • Auteur: Julio
  • Geschatte tijd: 5 minuten
  • Moeilijkheid: Zeer eenvoudig
Stap 1 Open the back panel  ¶
Remove the back cover by lifting at the notch towards the bottom of the phone. Use your fingernail to pry up.
  • Remove the back cover by lifting at the notch towards the bottom of the phone. Use your fingernail to pry up.
Stap 2 Pull the the cover up.  ¶
Use one hand to pull the cover up, and the other hand to hold the phone down.
  • Use one hand to pull the cover up, and the other hand to hold the phone down.
Stap 3 Remove the Battery  ¶
Pull the battery up from the lower left corner.
  • Pull the battery up from the lower left corner.
Stap 4 Battery replacement  ¶
Now, you can put the new battery in, then replace the cover.
  • Now, you can put the new battery in, then replace the cover.
