Help
ASUS PadFone X Station USB Charging Port Replacement
Betere introductie
Betere introductie
Verbeter deze handleiding door het afmaken of herzien van de introductie.
You will be replacing the USB Charging Port using a Phillips head screwdriver.
  • Auteur: Daniel
  • Geschatte tijd: 5 - 10 minuten
  • Moeilijkheid: Gemiddeld
Stap 1 Check USB Charging Port for water damage  ¶
Locate CON2002 Check water indicator on USB Charging Port
  • Locate CON2002
  • Check water indicator on USB Charging Port
  • A white indicator means there is no water damage. A red indicator means there was water damage.
Stap 2 Removing Charging Port  ¶
Locate and remove three Phillips screws
  • Locate and remove three Phillips screws
Stap 3 Disconnect E893821  ¶
Use a pair of tweezers to disconnect E893821
  • Use a pair of tweezers to disconnect E893821
