Ga door naar hoofdinhoud
Help
Crayola Crayon Maker Sliding Lock Mechanism Replacement
Clear plastic sliding lock mechanism can become dislodged from proper location. This causes the device's lid not to lock.
  • Auteur: Heidi Clarke
  • Geschatte tijd: 15 - 20 minuten
  • Moeilijkheid: Gemiddeld
If lid is closing but not latching, read the instructions in this guide to help you determine and fix the problem.
Stap 1 Remove the green base from the crayon maker  ¶
Flip the crayon maker. Remove six screws (2 cm in length) with a spanner. Remove the green base plate and set it aside.
  • Flip the crayon maker.
  • Remove six screws (2 cm in length) with a spanner.
  • Remove the green base plate and set it aside.
Stap 2 Locate the Plastic arm  ¶
Locate the clear plastic arm inside the control box. Locate the clear plastic arm inside the control box. Locate the clear plastic arm inside the control box.
  • Locate the clear plastic arm inside the control box.
Stap 3 Adjust/Replace the Plastic Arm  ¶
If necessary, unscrew the plastic arm with a Phillips #00 Precision screwdriver and readjust the arm until the desired position is reached. If the plastic arm is broken, contact Crayola for replacement parts.
  • If necessary, unscrew the plastic arm with a Phillips #00 Precision screwdriver and readjust the arm until the desired position is reached.
  • If the plastic arm is broken, contact Crayola for replacement parts.
