Ga door naar hoofdinhoud
Help
LG G3 Rear Speaker Replacement
Stap gemist
Stap gemist
Oeps! Deze handleiding mist nu een paar belangrijke stappen.
Replacing the rear speaker on the LG G3.
  • Auteur: Shannon
  • Geschatte tijd: 5 minuten
  • Moeilijkheid: Eenvoudig
The rear speaker is attached to the bottom panel of the LG G3, so to resolve any problems with the rear speaker, a full replacement of the bottom panel is necessary.
Stap 1 Rear Speaker  ¶
Remove the 13 screws found on the back of the phone. The screw circled in red is shorter than the other 12 screws. For an easier time when reassembling the phone, store it separately from the other screws.
  • Remove the 13 screws found on the back of the phone.
  • The screw circled in red is shorter than the other 12 screws. For an easier time when reassembling the phone, store it separately from the other screws.
Stap 2  ¶
Locate the same gap used in the earlier step Lift gently using your fingers
Stap 2  ¶
  • Locate the same gap used in the earlier step
  • Lift gently using your fingers
Stap 3  ¶
Remove the bottom panel
Stap 3  ¶
  • Remove the bottom panel
Stap 4  ¶
remove the speaker from the rear panel and insert the new speaker
Stap 4  ¶
  • remove the speaker from the rear panel and insert the new speaker
