Ga door naar hoofdinhoud
Help
Huawei Y300 LCD Screen Replacement
Onjuiste gereedschappen
Help om deze handleiding beter te maken door de juiste gereedschappen in plaatjes en/of tekst te gebruiken.
Mislukte opmaak
Mislukte opmaak
Deze handleiding heeft een betere opmaak nodig. Help mee door het corrigeren van de opmaak of door aantekeningen te maken.
Betere introductie
Betere introductie
Verbeter deze handleiding door het afmaken of herzien van de introductie.
A repair guide on how to replace the LCD display in the Huawei Y300 android smartphone
  • Auteur: Shuti Wu
  • Geschatte tijd: 5 - 10 minuten
  • Moeilijkheid: Eenvoudig
In this guide we are going to replace the LCD display on the Huawei ascend Y300 android smartphone. Before we start it is a good idea to prepare an organised area to carry out the repair, it is also a good Idea to get a small bowl or parts tray to put the small screws in so that they aren't lost.
Stap 1 Battery  ¶
Remove the rear cover at the back by pulling the gap located at the bottom of the phone. Lift up and remove the battery
Stap 1 Battery  ¶
  • Remove the rear cover at the back by pulling the gap located at the bottom of the phone.
  • Lift up and remove the battery
Stap 2  ¶
Leave the phone down on a table. 8 screws are what we need to remove next. There is one hiding below a white sticker 8 screws are what we need to remove next. There is one hiding below a white sticker
Stap 2  ¶
  • Leave the phone down on a table.
  • 8 screws are what we need to remove next. There is one hiding below a white sticker
Stap 3  ¶
Use a screwdriver (T4 if you are using the 54 bit driver kit) to remove the 8  screws along the edges of the phone. There are four in each corner and four in the middle on the sides. Put the screws on the magnetic mat/parts tray or bowl to make sure they are not lost.
Stap 3  ¶
  • Use a screwdriver (T4 if you are using the 54 bit driver kit) to remove the 8 screws along the edges of the phone. There are four in each corner and four in the middle on the sides.
  • Put the screws on the magnetic mat/parts tray or bowl to make sure they are not lost.
Stap 4  ¶
Use the black plastic opening tool by fitting it into the gaps to pull back the frame. Use the black plastic opening tool by fitting it into the gaps to pull back the frame. Use the black plastic opening tool by fitting it into the gaps to pull back the frame.
Stap 4  ¶
  • Use the black plastic opening tool by fitting it into the gaps to pull back the frame.
Stap 5  ¶
On the left of the motherboard there is a ribbon cable that connects the volume rocker to the motherboard, we need to disconnect it. To do this, using either the spudger or tweezers lift up the retention flap holding the cable down. Next using the tweezers carefully pull the ribbon cable away from the socket it was in until it is completely clear of the connector.
Stap 5  ¶
  • On the left of the motherboard there is a ribbon cable that connects the volume rocker to the motherboard, we need to disconnect it.
  • To do this, using either the spudger or tweezers lift up the retention flap holding the cable down.
  • Next using the tweezers carefully pull the ribbon cable away from the socket it was in until it is completely clear of the connector.
Stap 6  ¶
There are two more ribbon cables at the top that must also be disconnected, to do this simply lift them up from their connecter with the tweezers or with the spudger.
Stap 6  ¶
  • There are two more ribbon cables at the top that must also be disconnected, to do this simply lift them up from their connecter with the tweezers or with the spudger.
Stap 7  ¶
Pull back the orange tab. Carefully disconnect this. Pull back the orange tab. Carefully disconnect this.
Stap 7  ¶
  • Pull back the orange tab. Carefully disconnect this.
Stap 8  ¶
Once the orange tabs are pulled back, use a plastic wedge to detach the LCD screen.
Stap 8  ¶
  • Once the orange tabs are pulled back, use a plastic wedge to detach the LCD screen.
  • Carefully pull the screen away from the cover and replace the LCD with a new one
