Ga door naar hoofdinhoud
Help
Jabra CRUISER2 Speaker Replacement
Follow this guide to remove the speaker if it is faulty or needs replacing.
  • Auteur: Spartacus
  • Geschatte tijd: 10 - 15 minuten
  • Moeilijkheid: Gemiddeld
Without the speaker, the speakerphone would be useless! This guide will tell you step-by-step how to remove and replace a faulty speaker.
Secties
Gereedschap
Stap 1 Speaker  ¶
Carefully unplug the red and black wires that run from the speaker to the motherboard by detaching the white connecting piece. Carefully unplug the red and black wires that run from the speaker to the motherboard by detaching the white connecting piece.
Stap 1 Speaker  ¶
  • Carefully unplug the red and black wires that run from the speaker to the motherboard by detaching the white connecting piece.
Stap 2  ¶
Using the PH000, unscrew the two 5.5mm screws attaching the speaker to the front plate.
Stap 2  ¶
  • Using the PH000, unscrew the two 5.5mm screws attaching the speaker to the front plate.
  • The screwdriver sizes are located on the sides of their heads.
Stap 3  ¶
Gently pull the black and red wires away from the back plate to remove the speaker.
Stap 3  ¶
  • Gently pull the black and red wires away from the back plate to remove the speaker.
Stap 4  ¶
Carefully pull the wires away from the speaker, detaching them from the adhesive, while keeping the ends intact. Carefully pull the wires away from the speaker, detaching them from the adhesive, while keeping the ends intact.
Stap 4  ¶
  • Carefully pull the wires away from the speaker, detaching them from the adhesive, while keeping the ends intact.
