Help
Sony Xperia Z3 Dual Back Cover Replacement
Handleiding met medewerking van leden
Een fantastisch lid van onze gemeenschap heeft deze handleiding gemaakt. Deze wordt niet bijgehouden door het team van iFixit.
This guide shows you how easy to replace Sony Xperia Z3 back cover.
  • Auteur: Sophia
  • Moeilijkheid: Gemiddeld
This guide shows you how easy to replace Sony Xperia Z3 back cover. And if the phone waterproof or not depends not only perfect operation but also the good back cover replacement parts.
Stap 1 Back Cover  ¶
Heat the back cover for about 1 to 2 minutes until you feel the adhesive sticker is soften a lot.
Stap 1 Back Cover  ¶
  • Heat the back cover for about 1 to 2 minutes until you feel the adhesive sticker is soften a lot.
Stap 2  ¶
Place the suction cup on top part or bottom part which you think is easy to carry and open a gap.
Stap 2  ¶
  • Place the suction cup on top part or bottom part which you think is easy to carry and open a gap.
Stap 3  ¶
Insert guitar pick into the gap and slide to cut the sticker around the back cover.
Stap 3  ¶
  • Insert guitar pick into the gap and slide to cut the sticker around the back cover.
Stap 4  ¶
Especially the left side, you'd better handle as the direction we marked or you are likely to break the flex cable on the left bottom corner.
Stap 4  ¶
  • Especially the left side, you'd better handle as the direction we marked or you are likely to break the flex cable on the left bottom corner.
Stap 5  ¶
Remove the back cover easily. It comes with camera lens and NFC.
Stap 5  ¶
  • Remove the back cover easily. It comes with camera lens and NFC.
  • And you can place your new back cover, press the adhesive sticker and done the replacement.
