Ga door naar hoofdinhoud
Help
iPhone 6 Volume Control Cable Replacement
Replace the volume control switches in an iPhone 6.
  • Auteur: Sam Goldheart
  • Geschatte tijd: 45 minuten - 2 uren
  • Moeilijkheid: Moeilijk
Use this guide to replace a malfunctioning volume control cable—this includes the electronic switches responsible for volume up and down, and the ring/silent control.
If you're looking to replace the physical button covers, we have a guide for that too: iPhone 6 Volume Control Buttons Replacement
Stap 1 Volume Control Cable  ¶
Remove the following Phillips #00 screws from the upper cable bracket:
  • Remove the following Phillips #00 screws from the upper cable bracket:
  • One 2.9 mm screw
  • One 2.2 mm screw
Stap 2  ¶
Remove the upper cable bracket from the iPhone. Remove the upper cable bracket from the iPhone.
Stap 2  ¶
  • Remove the upper cable bracket from the iPhone.
Stap 3  ¶
Remove the following four Phillips #00 screws from the contact bracket:
Stap 3  ¶
  • Remove the following four Phillips #00 screws from the contact bracket:
  • One 1.5 mm screw
  • One 1.4 mm screw
  • Two 2.1 mm screws
Stap 4  ¶
Remove the contact bracket from the iPhone. Remove the contact bracket from the iPhone.
Stap 4  ¶
  • Remove the contact bracket from the iPhone.
Stap 5  ¶
Use the flat end of a spudger to lift the volume control cable connector up off of its socket. Only pry up on the connector, not the socket on the logic board or you risk permanent damage.
Stap 5  ¶
  • Use the flat end of a spudger to lift the volume control cable connector up off of its socket.
  • Only pry up on the connector, not the socket on the logic board or you risk permanent damage.
Stap 6  ¶
Remove the following Phillips #00 screws from the volume control cable brackets:
Stap 6  ¶
  • Remove the following Phillips #00 screws from the volume control cable brackets:
  • Two 2.3 mm screws
  • One 1.8 mm scew
Stap 7  ¶
Pull the hold switch and volume control button brackets away from the rear case to allow access to the button covers. Pull the hold switch and volume control button brackets away from the rear case to allow access to the button covers. Pull the hold switch and volume control button brackets away from the rear case to allow access to the button covers.
Stap 7  ¶
  • Pull the hold switch and volume control button brackets away from the rear case to allow access to the button covers.
Stap 8  ¶
Begin to peel the volume control button cable up from the rear case starting from the connector end. Be gentle when peeling the thin portions of the cable up from the case. Remove the volume control button cable from the rear case.
Stap 8  ¶
  • Begin to peel the volume control button cable up from the rear case starting from the connector end.
  • Be gentle when peeling the thin portions of the cable up from the case.
  • Remove the volume control button cable from the rear case.
