Help
Apple Universal Dock Model A1256 Teardown
Uit elkaar gehaald
Uit elkaar gehaald
Demontages bieden een kijkje in een device en moeten niet worden gebruikt als demontage instructies.
Handleiding met medewerking van leden
Een fantastisch lid van onze gemeenschap heeft deze handleiding gemaakt. Deze wordt niet bijgehouden door het team van iFixit.
A simple look into the Universal Dock
Need a flat nose screw driver 2.4mm
philip screw driver #1
Stap 1 Apple Universal Dock Model A1256 Teardown  ¶
Pry along the edge of the bottom of the case. It will just pop out.
  • Pry along the edge of the bottom of the case. It will just pop out.
Stap 2  ¶
Remove the top case from the bottom.
Stap 2  ¶
  • Remove the top case from the bottom.
Stap 3  ¶
There are five Phillips screws holding the metal brace down (In the picture I have already removed them).
Stap 3  ¶
  • There are five Phillips screws holding the metal brace down (In the picture I have already removed them).
Stap 4  ¶
The brace is glued in near the ir-sensor. You may have to apply a little bit force to remove it, but it will come out with just pulling. (You can pry it a little bit with a spudger or a screwdriver) The brace is glued in near the ir-sensor. You may have to apply a little bit force to remove it, but it will come out with just pulling. (You can pry it a little bit with a spudger or a screwdriver)
Stap 4  ¶
  • The brace is glued in near the ir-sensor. You may have to apply a little bit force to remove it, but it will come out with just pulling. (You can pry it a little bit with a spudger or a screwdriver)
Stap 5  ¶
The only major chip located on the circuit board. (All those who have wondered about the dock's line out, I think we are clear now.) The only major chip located on the circuit board. (All those who have wondered about the dock's line out, I think we are clear now.)
Stap 5  ¶
  • The only major chip located on the circuit board. (All those who have wondered about the dock's line out, I think we are clear now.)
