Help
Nokia XL Dual SIM Motherboard Replacement
Replace your Nokia XL Dual SIM motherboard.
This replacement guide will save you from having to buy a new phone by showing you how to replace the motherboard of your Nokia XL Dual SIM Android Smartphone.
Stap 1 Removing Connectors  ¶
With tweezers, gently unsnap the motherboard connectors for all components. The location of all the connectors is indicated in the next step.
  • With tweezers, gently unsnap the motherboard connectors for all components.
  • The location of all the connectors is indicated in the next step.
Stap 2 Connector Locations  ¶
The 3 motherboard connectors for the touchscreen, volume buttons, and power/screen lock button assembly are indicated on the picture. The touchscreen assembly can now be removed and set aside. The motherboard connector for the front camera is indicated on the picture.
  • The 3 motherboard connectors for the touchscreen, volume buttons, and power/screen lock button assembly are indicated on the picture.
  • The touchscreen assembly can now be removed and set aside.
  • The motherboard connector for the front camera is indicated on the picture.
  • The motherboard connector for the camera flash, vibrator, and headphone jack assembly is indicated in the picture.
Stap 3 Remove motherboard  ¶
Gently pry up on the top underside of the motherboard with the small plastic opening tool. Gently pulling upward on the motherboard will allow it to be removed.
  • Gently pry up on the top underside of the motherboard with the small plastic opening tool.
  • Gently pulling upward on the motherboard will allow it to be removed.
