Ga door naar hoofdinhoud
Help
MacBook Core Duo LCD Panel Replacement
Replace a broken MacBook Core Duo LCD panel rather than the entire display assembly.
  • Auteur: iRobot
  • Geschatte tijd: 1 - 2 uren
  • Moeilijkheid: Moeilijk
Save money by replacing just your MacBook Core Duo's LCD screen without the inverter, cables, or bezels.
Secties
Stap 1 LCD Panel  ¶
Turn the LCD panel assembly over so that the screen is face down. You may want to use a cloth on your worksurface to prevent scratching the screen.
Stap 1 LCD Panel  ¶
  • Turn the LCD panel assembly over so that the screen is face down. You may want to use a cloth on your worksurface to prevent scratching the screen.
  • Peel up all the yellow tape securing the display data and iSight cables to the back of the LCD panel.
  • You'll need to transfer the tape over to your new display when reassembling the computer.
Stap 2  ¶
Disconnect the display data cable from the back of the display.
Stap 2  ¶
  • Disconnect the display data cable from the back of the display.
Stap 3  ¶
Disconnect the iSight cable from the top of the display.
Stap 3  ¶
  • Disconnect the iSight cable from the top of the display.
Stap 4  ¶
Lift up the display data and iSight cables and move them to the side. It is not necessary to entirely remove these cables from the display assembly.
Stap 4  ¶
  • Lift up the display data and iSight cables and move them to the side. It is not necessary to entirely remove these cables from the display assembly.
  • De-route the microphone cable from the right side of the LCD assembly.
  • On Core 2 Duo models, also de-route the antenna cable from the left side of the LCD assembly.
Stap 5  ¶
Remove the three 3.1 mm Phillips screws along the left edge of the display.
Stap 5  ¶
  • Remove the three 3.1 mm Phillips screws along the left edge of the display.
Stap 6  ¶
Remove the two 3.1 mm Phillips screws securing the iSight holder to the top of the display.
Stap 6  ¶
  • Remove the two 3.1 mm Phillips screws securing the iSight holder to the top of the display.
  • Make sure to remove the screws securing the metal bracket to the edge of the display and not the screws in the iSight board itself.
  • If you are replacing your screen with a new one, your part may not have these two screw holes. That's OK. You can still reassemble your computer without those screws in place.
Stap 7  ¶
Remove the three 3.1 mm Phillips screws along the right edge of the display.
Stap 7  ¶
  • Remove the three 3.1 mm Phillips screws along the right edge of the display.
Stap 8  ¶
Lift up the LCD panel by its bottom edge and slide it out of the metal mounting brackets.
Stap 8  ¶
  • Lift up the LCD panel by its bottom edge and slide it out of the metal mounting brackets.
