Ga door naar hoofdinhoud
Help
MacBook Pro 15" Unibody Mid 2010 Display Replacement
Replace a broken display assembly on your Mid 2010 MacBook Pro 15" Unibody.
  • Auteur: Andrew Bookholt
  • Geschatte tijd: 1 - 2 uren
  • Moeilijkheid: Gemiddeld
Replacing a broken display assembly gives you a new LCD, front glass, display enclosure, iSight camera, and new AirPort antennas.
Secties
Gereedschap
Stap 1 Display  ¶
Use the flat end of a spudger to carefully pry the AirPort/Bluetooth ribbon cable up off its socket on the logic board.
Stap 1 Display  ¶
  • Use the flat end of a spudger to carefully pry the AirPort/Bluetooth ribbon cable up off its socket on the logic board.
Stap 2  ¶
Pull the camera cable connector straight out of its socket on the logic board.
Stap 2  ¶
  • Pull the camera cable connector straight out of its socket on the logic board.
  • Pull the cable parallel to the face of the logic board toward the optical drive opening.
Stap 3  ¶
Use the tip of a spudger to pry the three antenna connectors up off the AirPort/Bluetooth board.
Stap 3  ¶
  • Use the tip of a spudger to pry the three antenna connectors up off the AirPort/Bluetooth board.
Stap 4  ¶
De-route all three antenna cables from their channels in the AirPort/Bluetooth housing. De-route the camera cable from its channel in the AirPort/Bluetooth housing.
Stap 4  ¶
  • De-route all three antenna cables from their channels in the AirPort/Bluetooth housing.
  • De-route the camera cable from its channel in the AirPort/Bluetooth housing.
Stap 5  ¶
Remove the following two screws securing the AirPort/Bluetooth housing to the upper case:
Stap 5  ¶
  • Remove the following two screws securing the AirPort/Bluetooth housing to the upper case:
  • One 3.8 mm Phillips
  • One 8.6 mm Phillips
Stap 6  ¶
Remove the AirPort/Bluetooth assembly from the upper case, minding any cables that may get caught.
Stap 6  ¶
  • Remove the AirPort/Bluetooth assembly from the upper case, minding any cables that may get caught.
Stap 7  ¶
Remove the 8.6 mm Phillips screw securing the antenna/camera cable retainer to the upper case. Remove the antenna/camera cable retainer from the upper case.
Stap 7  ¶
  • Remove the 8.6 mm Phillips screw securing the antenna/camera cable retainer to the upper case.
  • Remove the antenna/camera cable retainer from the upper case.
Stap 8  ¶
Remove two of the three 6 mm T6 Torx screws securing the right side of the display to the upper case.
Stap 8  ¶
  • Remove two of the three 6 mm T6 Torx screws securing the right side of the display to the upper case.
  • We purposely have you leave one screw attaching the display to the upper case to aid in future steps.
Stap 9  ¶
Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer. Pull the display data cable straight out of its socket on the logic board. Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
Stap 9  ¶
  • Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
  • Pull the display data cable straight out of its socket on the logic board.
  • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
Stap 10  ¶
Remove the 8.6 mm Phillips screw securing the display data cable retainer to the upper case. Remove the display data cable retainer from the upper case.
Stap 10  ¶
  • Remove the 8.6 mm Phillips screw securing the display data cable retainer to the upper case.
  • Remove the display data cable retainer from the upper case.
Stap 11  ¶
Remove two of the three 6 mm T6 Torx screws securing the left side of the display to the upper case.
Stap 11  ¶
  • Remove two of the three 6 mm T6 Torx screws securing the left side of the display to the upper case.
Stap 12  ¶
Open your MacBook Pro so the display is perpendicular to the upper case.
Stap 12  ¶
  • Open your MacBook Pro so the display is perpendicular to the upper case.
  • Place your opened MacBook Pro on a table as pictured.
  • While holding the display and upper case together with your left hand, remove the remaining T6 Torx screw from the upper display bracket.
Stap 13  ¶
Be sure to hold the display and upper case together with your left hand. Failure to do so may cause the freed display/upper case to fall, potentially damaging each component.
Stap 13  ¶
  • Be sure to hold the display and upper case together with your left hand. Failure to do so may cause the freed display/upper case to fall, potentially damaging each component.
  • Remove the last remaining T6 Torx screw securing the display to the upper case.
Stap 14  ¶
Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case. Rotate the display slightly away from the upper case. Lift the display up and away from the upper case, minding any brackets or cables that may get caught.
Stap 14  ¶
  • Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
  • Rotate the display slightly away from the upper case.
  • Lift the display up and away from the upper case, minding any brackets or cables that may get caught.
