Ga door naar hoofdinhoud
Help
Samsung Galaxy Tab 3 8.0 Charging Port Replacement
Betere introductie
Betere introductie
Verbeter deze handleiding door het afmaken of herzien van de introductie.
If the device will not charge despite a power cable and battery replacement, replacing this component is the likely solution.
  • Auteur: Peter Paoletta
  • Geschatte tijd: 20 - 30 minuten
  • Moeilijkheid: Eenvoudig
Stap 1 Unscrew Charging Port  ¶
Unscrew the 2.9mm screws from the charging port with Phillips Head #000 and use the spudger to pry it up from under the port to remove component from the device. Unscrew the 2.9mm screws from the charging port with Phillips Head #000 and use the spudger to pry it up from under the port to remove component from the device. Unscrew the 2.9mm screws from the charging port with Phillips Head #000 and use the spudger to pry it up from under the port to remove component from the device.
  • Unscrew the 2.9mm screws from the charging port with Phillips Head #000 and use the spudger to pry it up from under the port to remove component from the device.
