Ga door naar hoofdinhoud
Help
Boogie Board Rip Copper Button Plate Replacement
The official troubleshooting guide for this device states that any repair be done by a professional. With this guide, you become the professional. Here is how to access the internal components and replace replace the copper button plate.
  • Auteur: Gareth
  • Geschatte tijd: 15 minuten
  • Moeilijkheid: Gemiddeld
This guide will provide the steps to access the internal components including the motherboard where the copper button plates are located.
Secties
Gereedschap
Stap 1 Copper Button Plate  ¶
Using tweezers gently go around the edges of the copper plate to remove the adhesive. Using tweezers gently go around the edges of the copper plate to remove the adhesive.
  • Using tweezers gently go around the edges of the copper plate to remove the adhesive.
Stap 2  ¶
Use tweezers to grip the outer edge of the copper plate and lift the button straight off. Use tweezers to grip the outer edge of the copper plate and lift the button straight off.
Stap 2  ¶
  • Use tweezers to grip the outer edge of the copper plate and lift the button straight off.
