Ga door naar hoofdinhoud
Help
MacBook Core Duo Right Speaker Replacement
MacBook Core Duo right speaker replacement.
  • Auteur: iRobot
  • Moeilijkheid: Moeilijk
Does your MacBook's music sound not quite right—or, rather, not right at all? Restore balanced sound to your laptop by replacing the right speaker.
Secties
Stap 1 Right Speaker  ¶
Remove the following 4 Phillips screws:
  • Remove the following 4 Phillips screws:
  • Three 3 mm Phillips securing the subwoofer and right speaker to the lower case.
  • One 7.5 mm Phillips securing the loop in the display data cable to the lower case.
Stap 2  ¶
Lift the right speaker out of its housing in the lower case.
Stap 2  ¶
  • Lift the right speaker out of its housing in the lower case.
Stap 3  ¶
Thread the subwoofer and right speaker beneath the display data and microphone cables.
Stap 3  ¶
  • Thread the subwoofer and right speaker beneath the display data and microphone cables.
Stap 4  ¶
Use a spudger to disconnect the right speaker connector from the logic board.
Stap 4  ¶
  • Use a spudger to disconnect the right speaker connector from the logic board.
