Help
Palm Zire 21 Screen Replacement
Onjuiste gereedschappen
Help om deze handleiding beter te maken door de juiste gereedschappen in plaatjes en/of tekst te gebruiken.
Heeft betere plaatjes nodig
Betere foto's zullen deze handleiding verbeteren. Help mee door het nemen, bewerken of uploaden van nieuwe foto's!
How to replace a screen on a Palm Zire 21.
Use this guide to replace a screen on a Palm Zire 21
Stap 1 Screen  ¶
Remove the two 0.8mm screws located on the back of the device. Remove the two 0.8mm screws located on the back of the device.
Stap 1 Screen  ¶
  • Remove the two 0.8mm screws located on the back of the device.
Stap 2  ¶
  Using tweezers, or something similar flip up the tab, releasing the wires located under the flap   Using tweezers, or something similar flip up the tab, releasing the wires located under the flap   Using tweezers, or something similar flip up the tab, releasing the wires located under the flap
Stap 2  ¶
  •  Using tweezers, or something similar flip up the tab, releasing the wires located under the flap
Stap 3  ¶
Using a Philips head screwdriver, remove the two screws located at the bottom of the board. Using a Philips head screwdriver, remove the two screws located at the bottom of the board.
Stap 3  ¶
  • Using a Philips head screwdriver, remove the two screws located at the bottom of the board.
Stap 4  ¶
Gently, remove the motherboard by lifting up exposing the screen. Gently, remove the motherboard by lifting up exposing the screen.
Stap 4  ¶
  • Gently, remove the motherboard by lifting up exposing the screen.
Stap 5  ¶
Carefully, remove the screen from the device by lifting up and replacing with a new one. Carefully, remove the screen from the device by lifting up and replacing with a new one.
Stap 5  ¶
  • Carefully, remove the screen from the device by lifting up and replacing with a new one.
