Ga door naar hoofdinhoud
Help
MacBook Core Duo C-Channel Replacement
Replacing the metal support beneath the display.
  • Auteur: iRobot
  • Moeilijkheid: Moeilijk
The C-channel is the metal support beneath the MacBook's display. Use this guide to replace yours if it's mangled or broken.
Secties
Stap 1 C-Channel  ¶
Remove the following 3 screws:
Stap 1 C-Channel  ¶
  • Remove the following 3 screws:
  • Two 3 mm Phillips near the right speaker.
  • One 6 mm Phillips threaded through a hole in a plastic finger above the subwoofer.
  • Be careful not to over-tighten the screw above the subwoofer too tight or the plastic could crack.
Stap 2  ¶
Lift the right speaker out of its housing and set it to the side.
Stap 2  ¶
  • Lift the right speaker out of its housing and set it to the side.
Stap 3  ¶
Using a spudger, gently pry up the white plastic slot and slide the metal c-channel to the right and away from the display.
Stap 3  ¶
  • Using a spudger, gently pry up the white plastic slot and slide the metal c-channel to the right and away from the display.
