Help
Acer Iconia B1-A71 LCD Display Replacement
Handleiding met medewerking van leden
Een fantastisch lid van onze gemeenschap heeft deze handleiding gemaakt. Deze wordt niet bijgehouden door het team van iFixit.
Acer Iconia B1 (Tablet) LCD Display Replacement
  • Auteur: ZFix
  • Geschatte tijd: 15 - 20 minuten
  • Moeilijkheid: Gemiddeld
The video is for fully disassemble the tablet, but you can follow the steps until the separating the LCD display.
Please SUBSCRIBE to my channel ツ
Stap 1 Acer Iconia B1-A71 LCD Display Replacement  ¶
Switch-off the tablet. If you can't switch it off, use the reset button to do this. With a cutter and a plastic tool remove the back cover.
  • Switch-off the tablet.
  • If you can't switch it off, use the reset button to do this.
  • With a cutter and a plastic tool remove the back cover.
  • If you have a memory card inside, don't forget to remove it!
Stap 2  ¶
First, disconnect the battery. Now, disconnect the loudspeaker and remove the back cover.
Stap 2  ¶
  • First, disconnect the battery.
  • Now, disconnect the loudspeaker and remove the back cover.
  • Remove all scotch tapes and disconnect the touch screen flex cable...
  • LCD display flex cable,
  • the microphone,
  • and the WiFi and Bluetooth antennas flex cables.
Stap 3  ¶
Unscrew 5x screws and rmove the main board. Unscrew 5x screws and rmove the main board. Unscrew 5x screws and rmove the main board.
Stap 3  ¶
  • Unscrew 5x screws and rmove the main board.
Stap 4  ¶
The battery is glued to the LCD display metal shield with a double sided adhesive tape. Use plastic tools and carefully remove it. Remove all tapes from the LCD display metal shield.
Stap 4  ¶
  • The battery is glued to the LCD display metal shield with a double sided adhesive tape.
  • Use plastic tools and carefully remove it.
  • Remove all tapes from the LCD display metal shield.
Stap 5  ¶
The LCD display is held by metal frame and some locking clips on it. Use a cutter and a plastic tool to separate the LCD. You have to work slowly so as not to break the display.
Stap 5  ¶
  • The LCD display is held by metal frame and some locking clips on it.
  • Use a cutter and a plastic tool to separate the LCD.
  • You have to work slowly so as not to break the display.
  • Now, install the new LCD display and reassemble the tablet.
  • Did you do it successfully?
  • Please SUBSCRIBE to my channel ツ
