Ga door naar hoofdinhoud
Help
iPhone 6 Plus LCD and Digitizer Replacement
Replace the LCD and digitizer (A.K.A. front panel) in your iPhone 6 Plus.
  • Auteur: Walter Galan
  • Geschatte tijd: 40 minuten - 1 uur
  • Moeilijkheid: Gemiddeld
For an easier repair, use our fix kit and follow this shorter guide to replace your iPhone’s entire screen.
For more advanced fixers, this guide will help you replace only the iPhone’s LCD and digitizer assembly (a.k.a. the bare “front panel”). This requires you to transfer several components from your original screen to the new one before installing it—including the front-facing camera, earpiece speaker, LCD shield plate, and home button assembly.
For all screen/display repairs, it's important to transfer the original home button onto the new display in order for Touch ID (fingerprint scanning) to function.
Stap 1 LCD and Digitizer  ¶
Remove the two 1.7 mm Phillips screws (one on top and one on bottom) securing the LCD shield plate to the display assembly. Remove the two 1.7 mm Phillips screws (one on top and one on bottom) securing the LCD shield plate to the display assembly.
  • Remove the two 1.7 mm Phillips screws (one on top and one on bottom) securing the LCD shield plate to the display assembly.
Stap 2  ¶
Remove three 1.3 mm Phillips screws from each side of the LCD shield plate (six total). Remove three 1.3 mm Phillips screws from each side of the LCD shield plate (six total).
Stap 2  ¶
  • Remove three 1.3 mm Phillips screws from each side of the LCD shield plate (six total).
Stap 3  ¶
The next step requires peeling one end of the home button cable (highlighted in red in the second picture) that is affixed to the back of the display assembly with strong adhesive. We highly recommend using an iOpener to heat the bottom of the display assembly, directly on top of the home button. The next step requires peeling one end of the home button cable (highlighted in red in the second picture) that is affixed to the back of the display assembly with strong adhesive. We highly recommend using an iOpener to heat the bottom of the display assembly, directly on top of the home button.
Stap 3  ¶
  • The next step requires peeling one end of the home button cable (highlighted in red in the second picture) that is affixed to the back of the display assembly with strong adhesive. We highly recommend using an iOpener to heat the bottom of the display assembly, directly on top of the home button.
Stap 4  ¶
Carefully lift—but do not remove—the  LCD shield plate by lifting the end nearest the earpiece speaker a few millimeters from the display assembly. Gently lift the other end (nearest the home button) to peel the home button cable off the display assembly. Be extremely cautious as you peel the home button cable. It is a fragile cable. If you feel more than slight resistance, we recommend reheating and reusing the iOpener to soften the adhesive.
Stap 4  ¶
  • Carefully lift—but do not remove—the LCD shield plate by lifting the end nearest the earpiece speaker a few millimeters from the display assembly.
  • Gently lift the other end (nearest the home button) to peel the home button cable off the display assembly.
  • Be extremely cautious as you peel the home button cable. It is a fragile cable. If you feel more than slight resistance, we recommend reheating and reusing the iOpener to soften the adhesive.
  • Remove the LCD shield plate off the display assembly.
  • Display assembly remains.
