Ga door naar hoofdinhoud
Help
iMac Intel 21.5" EMC 2805 Hard Drive Assembly Replacement
Alleen vereisten
Alleen vereisten
Houd er rekening mee dat dit slechts een vereiste handleiding is voor andere handleidingen.
Prereq only for removing the logic board, fan and power supply are out.
Gereedschap
Stap 1 Hard Drive Assembly  ¶
Lift the hard drive from the edge nearest the logic board and pull it slightly out of its recess. The hard drive is attached by a single SATA power/data cable—do not attempt to fully remove it from the iMac yet. The hard drive is attached by a single SATA power/data cable—do not attempt to fully remove it from the iMac yet.
  • Lift the hard drive from the edge nearest the logic board and pull it slightly out of its recess.
  • The hard drive is attached by a single SATA power/data cable—do not attempt to fully remove it from the iMac yet.
Stap 2  ¶
Use a spudger to disconnect the single SATA power and data combo cable by gently prying its large plastic connector away from the hard drive. Use a spudger to disconnect the single SATA power and data combo cable by gently prying its large plastic connector away from the hard drive.
Stap 2  ¶
  • Use a spudger to disconnect the single SATA power and data combo cable by gently prying its large plastic connector away from the hard drive.
Stap 3  ¶
Remove the hard drive assembly from the iMac.
Stap 3  ¶
  • Remove the hard drive assembly from the iMac.
