Ga door naar hoofdinhoud
Help
Sony Ericsson T68i Keypad Replacement
Ontbrekende vereisten
Deze handleiding heeft ontbrekende informatie over het starten van het proces. Maak een handleiding met de vereiste stappen!
This guide will help you to remove the keypad from your Sony Ericsson T68i.
Stap 1 Keypad  ¶
Remove the battery from the back. Remove the battery from the back.
Stap 1 Keypad  ¶
  • Remove the battery from the back.
Stap 2  ¶
Pry off the plastic cover from the top with a thin plastic shim, then remove it from the two bottom clips. Do not bend it too far down, or else you risk breaking the two bottom clips. Do not bend it too far down, or else you risk breaking the two bottom clips.
Stap 2  ¶
  • Pry off the plastic cover from the top with a thin plastic shim, then remove it from the two bottom clips.
  • Do not bend it too far down, or else you risk breaking the two bottom clips.
Stap 3  ¶
Unscrew all four Torx T6 screws. Keep in a safe place. Keep in a safe place.
Stap 3  ¶
  • Unscrew all four Torx T6 screws.
  • Keep in a safe place.
Stap 4  ¶
After removing the screws, the two halves will separate. If not, then pry them gently apart. After removing the screws, the two halves will separate. If not, then pry them gently apart. After removing the screws, the two halves will separate. If not, then pry them gently apart.
Stap 4  ¶
  • After removing the screws, the two halves will separate. If not, then pry them gently apart.
