Ga door naar hoofdinhoud
Help
Sony Cyber-shot DSC-W150 Front Casing Replacement
Grammaticapolitie
Grammaticapolitie
Laat je innerlijke leraar Nederlands vrij en help om de grammatica van deze handleiding te verbeteren!
Handleiding met medewerking van leden
Een fantastisch lid van onze gemeenschap heeft deze handleiding gemaakt. Deze wordt niet bijgehouden door het team van iFixit.
  • Auteur: Julio Maravilla
  • Geschatte tijd: 10 minuten
  • Moeilijkheid: Eenvoudig
This page will guide you through the removal of the front casing on the Sony Cyber-shot DSC W150.
Secties
Gereedschap
Stap 1 Front Casing  ¶
Keep track of the small screws that you remove.
  • Keep track of the small screws that you remove.
  • Opening, removing and/or replacing the front casing may void your manufacturers warranty
Stap 2  ¶
Remove the two screws at the top of the camera casing.
Stap 2  ¶
  • Remove the two screws at the top of the camera casing.
Stap 3  ¶
Gently pop open the plastic piece as shown.
Stap 3  ¶
  • Gently pop open the plastic piece as shown.
Stap 4  ¶
Remove the screw connecting the front casing to the electrical components as shown.
Stap 4  ¶
  • Remove the screw connecting the front casing to the electrical components as shown.
Stap 5  ¶
Gently loosen and remove the side casing by firmly pulling with your fingers.
Stap 5  ¶
  • Gently loosen and remove the side casing by firmly pulling with your fingers.
  • Take care not to break the fragile part or to scratch the LCD screen.
Stap 6  ¶
Remove the two screws connecting the front casing to the electrical components.
Stap 6  ¶
  • Remove the two screws connecting the front casing to the electrical components.
Stap 7  ¶
Gently loosen the front casing.
Stap 7  ¶
  • Gently loosen the front casing.
  • Be careful not to scratch any of the exposed electrical components.
Stap 8  ¶
Fully remove the front casing from the camera.
Stap 8  ¶
  • Fully remove the front casing from the camera.
