Ga door naar hoofdinhoud
Help
Toshiba Satellite M45 Wi-Fi Card Replacement
  • Auteur: Sophie Schneider
  • Geschatte tijd: 5 - 10 minuten
  • Moeilijkheid: Zeer eenvoudig
Learn to replace your wifi card.
Stap 1 Wi-Fi Card  ¶
Remove the panel screw labeled with a #1 Phillips head screwdriver  as indicated in the picture, then use a flat edge tool to pry the cover off. The hardware to the left (labeled) can be easily removed by disconnecting the black and white wires and pushing the tabs that secure it (located on the side) outwards. Pull the Wi-Fi card out from the device at a slight angle (horizontal with the casing).
Stap 1 Wi-Fi Card  ¶
  • Remove the panel screw labeled with a #1 Phillips head screwdriver as indicated in the picture, then use a flat edge tool to pry the cover off.
  • The hardware to the left (labeled) can be easily removed by disconnecting the black and white wires and pushing the tabs that secure it (located on the side) outwards.
  • Pull the Wi-Fi card out from the device at a slight angle (horizontal with the casing).
