Help
Sony PlayStation Teardown
Uit elkaar gehaald
Uit elkaar gehaald
Demontages bieden een kijkje in een device en moeten niet worden gebruikt als demontage instructies.
Handleiding met medewerking van leden
Een fantastisch lid van onze gemeenschap heeft deze handleiding gemaakt. Deze wordt niet bijgehouden door het team van iFixit.
I have a PlayStation 1, and i have decided to make a new teardown of it.
I'm spanish, so my english is a bit poor, and sorry for the mistakes made in this teardown.
Without further delay, we start.
Stap 1 Sony PlayStation Teardown  ¶
Here's the PS1. Turn the PS1 over and remove the six screws.
  • Here's the PS1.
  • Turn the PS1 over and remove the six screws.
Stap 2  ¶
Remove the top cover. It's very easy.
Stap 2  ¶
  • Remove the top cover. It's very easy.
Stap 3  ¶
Disconnect both CD-ROM connectors.
Stap 3  ¶
  • Disconnect both CD-ROM connectors.
  • CD connector one and the socket it connects to.
  • CD connector two and the socket it connects to.
Stap 4  ¶
Remove the CD-ROM reader. You should be able to pull it out gently, although you may have to wiggle it around a bit to loosen the rubber holders. Remove the CD-ROM reader. You should be able to pull it out gently, although you may have to wiggle it around a bit to loosen the rubber holders.
Stap 4  ¶
  • Remove the CD-ROM reader. You should be able to pull it out gently, although you may have to wiggle it around a bit to loosen the rubber holders.
Stap 5  ¶
Detach both cables. They go to the power supply and to the memory cards and controller connectors.
Stap 5  ¶
  • Detach both cables. They go to the power supply and to the memory cards and controller connectors.
Stap 6  ¶
Remove the four screws and the metal cover.
Stap 6  ¶
  • Remove the four screws and the metal cover.
Stap 7  ¶
Now you have the motherboard!
Stap 7  ¶
  • Now you have the motherboard!
  • And the power supply.
  • Remove the four screws from the motherboard and the power supply.
Stap 8  ¶
Once the screws are removed, remove the power supply.
Stap 8  ¶
  • Once the screws are removed, remove the power supply.
Stap 9  ¶
Remove the motherboard, and both of the screws from the memory card/ controller connection mechanism.
Stap 9  ¶
  • Remove the motherboard, and both of the screws from the memory card/ controller connection mechanism.
Stap 10  ¶
Now, you have all your PlayStation 1 parts!
Stap 10  ¶
  • Now, you have all your PlayStation 1 parts!
  • Main Board
  • Lower Casing
  • EMI Shield
  • Power Supply
  • Disk Reader
  • Memory Card/ Controller Mechanism
