Ga door naar hoofdinhoud
Help
Sony Ericsson Z500a Logic Board Replacement
Stappen inkorten
Stappen inkorten
Deze handleiding heeft onnodige stappen. Kort ze in om beknopter te kunnen zijn!
  • Auteur: Tim
  • Geschatte tijd: 5 - 10 minuten
  • Moeilijkheid: Eenvoudig
The Logic Board is the part that the keys hit and translates the signals to the phone.
Secties
Gereedschap
Stap 1 Logic Board  ¶
Use the i Pod opening tool to remove the 2 ribbon wires (boxed in the photo) from the logic board.
  • Use the i Pod opening tool to remove the 2 ribbon wires (boxed in the photo) from the logic board.
Stap 2  ¶
Gently lift the back of the logic board and then pull outwards. Be careful not to rip the ribbon wire.
Stap 2  ¶
  • Gently lift the back of the logic board and then pull outwards. Be careful not to rip the ribbon wire.
Stap 3  ¶
If the parts are loose you can remove the black sim card reader and green vibrator before continuing, otherwise they may fall out. If the parts are loose you can remove the black sim card reader and green vibrator before continuing, otherwise they may fall out.
Stap 3  ¶
  • If the parts are loose you can remove the black sim card reader and green vibrator before continuing, otherwise they may fall out.
