Help
PowerBook G4 Aluminum 17" 1-1.67 GHz Heat Sink & Fan Assembly Replacement
  • Auteur: iRobot
  • Geschatte tijd: 1 - 3 uren
  • Moeilijkheid: Moeilijk
The heat sink and fan together help to keep the processor cool and happy.
Stap 1 Heat Sink & Fan Assembly  ¶
Remove seven Torx T8 screws from the heat sink and fan assembly.
  • Remove seven Torx T8 screws from the heat sink and fan assembly.
  • The screw in the upper, right corner is smaller than the others.
Stap 2  ¶
Lift the heat sink and fan assembly out of the computer.
Stap 2  ¶
  • Lift the heat sink and fan assembly out of the computer.
  • If you need to mount the heat sink back into the laptop, we have a thermal paste guide that makes replacing the thermal compound easy.
