Help
Nikon D5000 Speaker Replacement
Replacement of the Nikon D5000's internal speaker.
  • Auteur: Jacob Rardin
  • Geschatte tijd: 15 minuten
  • Moeilijkheid: Gemiddeld
If your camera stops making noise, or the sound is distorted, you may want to inspect or replace the speaker.
Stap 1 Speaker  ¶
The speaker is mounted to the underside of the back panel. There is a a metal shield that holds it on. Remove the four Phillips #00 screws securing the shield:
Stap 1 Speaker  ¶
  • The speaker is mounted to the underside of the back panel. There is a a metal shield that holds it on.
  • Remove the four Phillips #00 screws securing the shield:
  • Three silver 3x4mm screws.
  • One black 3x3mm screw.
  • Remove the shield.
  • With the shield off, the navigation buttons and "Lv" button are free to move and rotate. Check alignment before replacement.
Stap 2  ¶
Lift the blue tape on the ribbon cable.
Stap 2  ¶
  • Lift the blue tape on the ribbon cable.
  • Desolder the two leads to the speaker.
Stap 3  ¶
Pry the speaker out of its cavity.
Stap 3  ¶
  • Pry the speaker out of its cavity.
