Ga door naar hoofdinhoud
Help
Dell Inspiron N5030 RAM Replacement
In this guide, you will learn how to disassemble the Dell Inspiron N5030 to find and replace your RAM.
  • Auteur: Rodrigo Perez
  • Geschatte tijd: 10 - 15 minuten
  • Moeilijkheid: Gemiddeld
If you want to upgrade your computer by putting in new RAM, or if you need to replace your RAM with new boards, use this guide to learn how to do it.
Secties
Gereedschap
Stap 1 RAM  ¶
Place your fingers on the two metal tabs  on the edges of the RAM.
Stap 1 RAM  ¶
  • Place your fingers on the two metal tabs on the edges of the RAM.
  • Push on the tabs in the opposite direction.
  • The top RAM board will pop up after you push on the metal tabs.
Stap 2  ¶
Pull the top RAM board out with your fingers.
Stap 2  ¶
  • Pull the top RAM board out with your fingers.
Stap 3  ¶
Repeat the above RAM board steps for the second RAM board. Repeat the above RAM board steps for the second RAM board. Repeat the above RAM board steps for the second RAM board.
Stap 3  ¶
  • Repeat the above RAM board steps for the second RAM board.
