Ga door naar hoofdinhoud
Help
Disassembling Nokia 3100b Microphone
Heeft betere plaatjes nodig
Betere foto's zullen deze handleiding verbeteren. Help mee door het nemen, bewerken of uploaden van nieuwe foto's!
Mislukte opmaak
Mislukte opmaak
Deze handleiding heeft een betere opmaak nodig. Help mee door het corrigeren van de opmaak of door aantekeningen te maken.
Stap gemist
Stap gemist
Oeps! Deze handleiding mist nu een paar belangrijke stappen.
This guide show you how to access the phone's microphone, the component that receives sound when making a call.
Secties
Gereedschap
Stap 1 Microphone  ¶
Press the black tabs to release the front cover from the phone.
Stap 1 Microphone  ¶
  • Press the black tabs to release the front cover from the phone.
Stap 2  ¶
Remove the front cover from the phone.
Stap 2  ¶
  • Remove the front cover from the phone.
  • Set the front cover, as indicated, aside.
Stap 3  ¶
Remove the screws as they are indicated in the order of the colors of the rainbow. (Red, Orange, Yellow, Green, Blue, Purple.)
Stap 3  ¶
  • Remove the screws as they are indicated in the order of the colors of the rainbow. (Red, Orange, Yellow, Green, Blue, Purple.)
Stap 4  ¶
Remove the screen assembly from the phone base.
Stap 4  ¶
  • Remove the screen assembly from the phone base.
  • Set the screen assembly aside.
Stap 5  ¶
Note the location of the microphone.
Stap 5  ¶
  • Note the location of the microphone.
Stap 6  ¶
Use tweezers to remove the microphone from the phone's base.
Stap 6  ¶
  • Use tweezers to remove the microphone from the phone's base.
Stap 7  ¶
The microphone is now removed.
Stap 7  ¶
  • The microphone is now removed.
