Help
HP 2000 - 2D22DX Wireless Card Replacement
Betere introductie
Betere introductie
Verbeter deze handleiding door het afmaken of herzien van de introductie.
This guide will show the user how to remove the device's wireless chip and install a new one, if necessary.
  • Auteur: Conor Most
  • Geschatte tijd: 5 - 10 minuten
  • Moeilijkheid: Gemiddeld
Secties
Gereedschap
Stap 1 Wireless Card  ¶
Locate the RAM compartment cover below the battery compartment. Locate the Phillips head screw securing RAM compartment to plastic chassis.
  • Locate the RAM compartment cover below the battery compartment.
  • Locate the Phillips head screw securing RAM compartment to plastic chassis.
  • Loosen screw that is securing the RAM compartment with #00 Phillips head screwdriver.
  • Screw is permanently attached to the RAM compartment cover. Do not try to remove completely.
Stap 2  ¶
Once the screw is sufficiently loosened, slowly unclip the RAM compartment cover from its slots in the plastic chassis. When unclipped completely, pull the compartment door out and away from the chassis.
Stap 2  ¶
  • Once the screw is sufficiently loosened, slowly unclip the RAM compartment cover from its slots in the plastic chassis.
  • When unclipped completely, pull the compartment door out and away from the chassis.
Stap 3  ¶
Locate the wireless module next to the RAM slots.
Stap 3  ¶
  • Locate the wireless module next to the RAM slots.
Stap 4  ¶
Locate the gold connecting wire attached to the wireless module. It is labeled with a small sticker that has a circled number one. Using a plastic spudger, disconnect the gold-end of the connecting wire from the wireless module. Use a slow, prying motion as if pulling a nail out of wood.
Stap 4  ¶
  • Locate the gold connecting wire attached to the wireless module. It is labeled with a small sticker that has a circled number one.
  • Using a plastic spudger, disconnect the gold-end of the connecting wire from the wireless module.
  • Use a slow, prying motion as if pulling a nail out of wood.
  • Be very gentle with the gold wire and its respective port on the wireless module. Both are very fragile and can be easily ruined.
Stap 5  ¶
Locate the small Phillips head screw in the top right corner of the wireless module. Using a #00 Phillips head screwdriver, remove the screw and set aside. The wireless module should now pop up from its slot at a 45 degree angle.
Stap 5  ¶
  • Locate the small Phillips head screw in the top right corner of the wireless module.
  • Using a #00 Phillips head screwdriver, remove the screw and set aside.
  • The wireless module should now pop up from its slot at a 45 degree angle.
Stap 6  ¶
Slowly slide the wireless module straight out from its slot in the logic board.
Stap 6  ¶
  • Slowly slide the wireless module straight out from its slot in the logic board.
  • Maintain the 45 degree angle of the wireless module until all pins are disconnected. Failure to do so may result in breaking the wireless module connecting pins.
