Ga door naar hoofdinhoud
Help
Internal Audio Adapter Jack Replacement
This guide shows you how to replace the internal audio adapter jack of the iHome iP37.
  • Auteur: Jerrell
  • Geschatte tijd: 15 minuten
  • Moeilijkheid: Gemiddeld
This guide details how to replace iHome iP37's internal audio adapter jack, which connects your music device to the iHome. Replacing the part doesn't take long.
Stap 1 Internal Audio Adapter Jack  ¶
A strip of black tape covers the grey and purple wire cluster that connects to the internal audio printed circuit board. Carefully peel this tape away.
  • A strip of black tape covers the grey and purple wire cluster that connects to the internal audio printed circuit board. Carefully peel this tape away.
Stap 2  ¶
Remove the four 7 mm screws that hold the PCB in place; you will need a Phillips #1 driver to do this. You may need to move some wires out of the way to access one of these screws.
Stap 2  ¶
  • Remove the four 7 mm screws that hold the PCB in place; you will need a Phillips #1 driver to do this. You may need to move some wires out of the way to access one of these screws.
Stap 3  ¶
Carefully lift and remove the black plastic bracket. Lift the PCB away from the rest of the device.
Stap 3  ¶
  • Carefully lift and remove the black plastic bracket.
  • Lift the PCB away from the rest of the device.
