Ga door naar hoofdinhoud
Help
HP Mini 210 Fan Replacement
Stap gemist
Stap gemist
Oeps! Deze handleiding mist nu een paar belangrijke stappen.
Actiemomenten
Actiemomenten
Wees een actieheld! Deze handleiding heeft plaatjes nodig die beter tonen hoe specifieke handelingen uitgevoerd moeten worden.
Heeft betere plaatjes nodig
Betere foto's zullen deze handleiding verbeteren. Help mee door het nemen, bewerken of uploaden van nieuwe foto's!
This is a step by step on how to replace the fan on a HP Mini 210.
  • Auteur: Irakoze Vincent
  • Geschatte tijd: 45 minuten - 1 uur
  • Moeilijkheid: Moeilijk
This guide will teach you how to perform a fan replacement on the HP Mini 210.
Secties
Stap 1 Fan  ¶
Use the spudger to peel the front black plastic plate from the rest of the case, starting at a corner and working your way around the entire case.
Stap 1 Fan  ¶
  • Use the spudger to peel the front black plastic plate from the rest of the case, starting at a corner and working your way around the entire case.
Stap 2  ¶
Locate the cable that connects the trackpad to the motherboard and carefully remove it.
Stap 2  ¶
  • Locate the cable that connects the trackpad to the motherboard and carefully remove it.
Stap 3  ¶
Use a screwdriver to remove the 9.3 mm screws on top of the motherboard. Use a screwdriver to remove the 9.3 mm screws on top of the motherboard.
Stap 3  ¶
  • Use a screwdriver to remove the 9.3 mm screws on top of the motherboard.
Stap 4  ¶
Remove the gold tape that holds the motherboard.
Stap 4  ¶
  • Remove the gold tape that holds the motherboard.
Stap 5  ¶
Use a spudger to carefully remove the motherboard.
Stap 5  ¶
  • Use a spudger to carefully remove the motherboard.
Stap 6  ¶
Flip over the motherboard to get to the fan. Carefully remove the cable that is attaches the fan to the motherboard.
Stap 6  ¶
  • Flip over the motherboard to get to the fan.
  • Carefully remove the cable that is attaches the fan to the motherboard.
  • Remove the screws that hold in the fan.
  • The fan is now able to be completely removed.
