Ga door naar hoofdinhoud
Help
Dell Inspiron 1750 Hard Drive Replacement
This guide will show you how to replace the hard drive of your Inspiron 1750.
  • Auteur: Tina Rickard
  • Geschatte tijd: 10 minuten
  • Moeilijkheid: Eenvoudig
You may want to remove the hard drive to upgrade to a higher capacity drive or if your files have become corrupted and unrecoverable.
Secties
Gereedschap
Stap 1 Hard Drive  ¶
Remove the two 1mm double wide Phillips #00 screws. Pull the hard drive away from the laptop.
Stap 1 Hard Drive  ¶
  • Remove the two 1mm double wide Phillips #00 screws.
  • Pull the hard drive away from the laptop.
Stap 2  ¶
Keep all screws in a safe place. You may need to use them for your new hard drive. Remove the two #00 1mm screws on both sides of the hard drive.
Stap 2  ¶
  • Keep all screws in a safe place. You may need to use them for your new hard drive.
  • Remove the two #00 1mm screws on both sides of the hard drive.
  • Pull the hard drive cover away from the hard drive and set the cover aside.
