Help
Motorola V276 Motherboard Replacement
Grammaticapolitie
Grammaticapolitie
Laat je innerlijke leraar Nederlands vrij en help om de grammatica van deze handleiding te verbeteren!
  • Auteur: Jonathan Cheung
  • Geschatte tijd: 10 minuten
  • Moeilijkheid: Gemiddeld
Replacing the Motorola V276 Motherboard
Stap 1 Motherboard  ¶
Use Spudger to remove rubber plug from upper left corner of the back of the phone
  • Use Spudger to remove rubber plug from upper left corner of the back of the phone
Stap 2  ¶
Using a Torx T6 screwdriver, remove the 4 screws holding the back plate of the phone in place
Stap 2  ¶
  • Using a Torx T6 screwdriver, remove the 4 screws holding the back plate of the phone in place
Stap 3  ¶
Three tabs will hold the back plastic plate in. To remove the back plate, pull the tabs towards the outside of the phone and lift the plate up simultaneously Be careful when removing the back plate; don't put too much stress on the back plate or the plastic may snap
Stap 3  ¶
  • Three tabs will hold the back plastic plate in.
  • To remove the back plate, pull the tabs towards the outside of the phone and lift the plate up simultaneously
  • Be careful when removing the back plate; don't put too much stress on the back plate or the plastic may snap
Stap 4  ¶
Using a Spudger remove the flex from the motherboard. Be delicate while removing the ribbon cable because it is slightly fragile and it is necessary for the phone to function Be delicate while removing the ribbon cable because it is slightly fragile and it is necessary for the phone to function
Stap 4  ¶
  • Using a Spudger remove the flex from the motherboard.
  • Be delicate while removing the ribbon cable because it is slightly fragile and it is necessary for the phone to function
Stap 5  ¶
Gently peel back the motherboard from the main part of the phone.
Stap 5  ¶
  • Gently peel back the motherboard from the main part of the phone.
