Ga door naar hoofdinhoud
Help
Siemens A56 Battery Replacement
Betere introductie
Betere introductie
Verbeter deze handleiding door het afmaken of herzien van de introductie.
This guide will describe the steps necessary to remove the back cover and replace the battery.
  • Auteur: Alex Garrett
  • Geschatte tijd: 10 seconden
  • Moeilijkheid: Zeer eenvoudig
Stap 1 Battery  ¶
Press down on the grooved area firmly in the direction of arrow #1.
Stap 1 Battery  ¶
  • Press down on the grooved area firmly in the direction of arrow #1.
  • While maintaining the downwards pressure, push the back cover in the direction of arrow #2 until the back cover slides off.
  • Photos taken from: http://theinformr.com/uploads/manuals/si...
Stap 2  ¶
Turn off the phone before removing the battery to avoid damage.
Stap 2  ¶
  • Turn off the phone before removing the battery to avoid damage.
  • Press the latch on the battery in the direction of arrow #3.
  • Lift battery at the cutout on the side of the phone, then tilt upwards and remove.
  • It may be necessary to use the tip of a fingernail or a plastic lifting tool to remove the battery.
