Ga door naar hoofdinhoud
Help
Disassembling Motorola i850 Keypad
Verwarrende Tekst
Verwarrende Tekst
Een deel van de tekst in deze handleiding is verwarrend, dubbelop of naast de kwestie. Bewerk de tekst en maak hem duidelijker!
  • Auteur: Tony Chen
  • Geschatte tijd: 10 - 15 minuten
  • Moeilijkheid: Gemiddeld
A procedure in replacing the keypad of the device.
Stap 1 Keypad  ¶
Once battery is removed, untighten the screws located near the edges of the device with a Phillips #00 Screwdriver.
Stap 1 Keypad  ¶
  • Once battery is removed, untighten the screws located near the edges of the device with a Phillips #00 Screwdriver.
Stap 2  ¶
Grip the device firmly with both hands and carefully open the device. Warning: Interior hardware inside the device can be easily damaged. Warning: Interior hardware inside the device can be easily damaged.
Stap 2  ¶
  • Grip the device firmly with both hands and carefully open the device.
  • Warning: Interior hardware inside the device can be easily damaged.
Stap 3  ¶
Carefully remove the hardware by gripping the side of the hardware attachment with a tweezer. Carefully remove the hardware by gripping the side of the hardware attachment with a tweezer.
Stap 3  ¶
  • Carefully remove the hardware by gripping the side of the hardware attachment with a tweezer.
Stap 4  ¶
Carefully grip the side of the hardware attachment with a tweezer and detach from device. Carefully grip the side of the hardware attachment with a tweezer and detach from device.
Stap 4  ¶
  • Carefully grip the side of the hardware attachment with a tweezer and detach from device.
Stap 5  ¶
Place the back of the device on your hand and flip it over with the other hand. Carefully lift the device to remove interior hardware. The structure of the keypad should easily be loose from flipping the device.
Stap 5  ¶
  • Place the back of the device on your hand and flip it over with the other hand.
  • Carefully lift the device to remove interior hardware.
  • The structure of the keypad should easily be loose from flipping the device.
Stap 6  ¶
Carefully remove the keypad by griping on the side of the plastic with a tweezer. WARNING: The plastic keypad is sensitive and can be easily damaged. WARNING: The plastic keypad is sensitive and can be easily damaged.
Stap 6  ¶
  • Carefully remove the keypad by griping on the side of the plastic with a tweezer.
  • WARNING: The plastic keypad is sensitive and can be easily damaged.
