Ga door naar hoofdinhoud
Help
iPhone 5c Speaker Replacement
Use this guide to replace the speaker assembly in your iPhone 5c.
Replace a broken speaker in an iPhone 5c to restore speakerphone capabilities.
Gereedschap (wordt vervolgd)
Relevante Onderdelen
Stap 1 Speaker  ¶
Use a plastic opening tool to peel the home button spring contact cable up from the speaker enclosure. Use a plastic opening tool to peel the home button spring contact cable up from the speaker enclosure.
Stap 1 Speaker  ¶
  • Use a plastic opening tool to peel the home button spring contact cable up from the speaker enclosure.
Stap 2  ¶
Remove the following screws securing the speaker enclosure to the rear case:
Stap 2  ¶
  • Remove the following screws securing the speaker enclosure to the rear case:
  • Two 2.7 mm Phillips #000 screws
  • One 2.2 mm Phillips #000 screw
Stap 3  ¶
Use the flat end of a spudger to gently pry the speaker enclosure up from the rear case. Use the flat end of a spudger to gently pry the speaker enclosure up from the rear case.
Stap 3  ¶
  • Use the flat end of a spudger to gently pry the speaker enclosure up from the rear case.
Stap 4  ¶
Remove the speaker enclosure. Be careful not to snag it on the antenna cable. Remove the speaker enclosure. Be careful not to snag it on the antenna cable. Remove the speaker enclosure. Be careful not to snag it on the antenna cable.
Stap 4  ¶
  • Remove the speaker enclosure. Be careful not to snag it on the antenna cable.
Stap 5  ¶
The far right screw hole on the speaker has a contact bracket wrapped around it. Remove it and note the orientation for reassembly. The flat portion of the contact clip should rest against the speaker, as shown.
Stap 5  ¶
  • The far right screw hole on the speaker has a contact bracket wrapped around it. Remove it and note the orientation for reassembly.
  • The flat portion of the contact clip should rest against the speaker, as shown.
  • The alignment bracket on the far end of the speaker assembly is adhered, but may fall off if handled aggressively.
  • The angled end should face up and line up with the outside edge of the speaker.
Stap 6  ¶
Your replacement speaker may be missing the contact-bearing sticker shown here; be sure to transfer it to the new part. Use a plastic opening tool to lift the sticker from the speaker.
Stap 6  ¶
  • Your replacement speaker may be missing the contact-bearing sticker shown here; be sure to transfer it to the new part.
  • Use a plastic opening tool to lift the sticker from the speaker.
  • Peel up and remove the sticker.
