Ga door naar hoofdinhoud
Help
Sony Vaio PCG-F420 RAM Replacement
Mislukte opmaak
Mislukte opmaak
Deze handleiding heeft een betere opmaak nodig. Help mee door het corrigeren van de opmaak of door aantekeningen te maken.
Onjuiste gereedschappen
Help om deze handleiding beter te maken door de juiste gereedschappen in plaatjes en/of tekst te gebruiken.
Replacing RAM module in the Sony VAIO PCG-F420
  • Auteur: Therin Irwin
  • Geschatte tijd: 10 - 15 minuten
  • Moeilijkheid: Eenvoudig
Upgrading or replacing the RAM modules in the laptop.
CAUTION: Static electricity from your body can damage RAM any component in your computer. Either use an anti-static wristband, or ground yourself periodically by touching a large piece of metal.
Stap 1 RAM  ¶
Remove the screw holding the RAM cover down.
Stap 1 RAM  ¶
  • Remove the screw holding the RAM cover down.
Stap 2  ¶
Use a flat object like a flat head screwdriver to lift the covering, revealing the RAM modules inside the computer.
Stap 2  ¶
  • Use a flat object like a flat head screwdriver to lift the covering, revealing the RAM modules inside the computer.
Stap 3  ¶
To remove the RAM currently inside the computer, gently pull out the white tabs on each side of the RAM module.
Stap 3  ¶
  • To remove the RAM currently inside the computer, gently pull out the white tabs on each side of the RAM module.
  • The RAM will pop up at an angle where it can be pulled out without damaging the socket.
  • Remove the RAM module by pulling at the same angle the RAM is at.
Stap 4  ¶
To insert the new RAM module, match the notch in the middle of the gold edge of the RAM to the notch in the laptop.
Stap 4  ¶
  • To insert the new RAM module, match the notch in the middle of the gold edge of the RAM to the notch in the laptop.
  • Insert the RAM at the same angle the other module came out at and make sure the end of the ram is actually in the slot. Gently push down on the RAM until it clicks in.
