Help
iRobot Roomba 551 Side Wheel Replacement
This is a quick guide explaining how to place the wheels of your Roomba.
  • Auteur: Deborah Newberry
  • Geschatte tijd: 5 - 15 minuten
  • Moeilijkheid: Eenvoudig
This is an easy way to quickly replace the side wheel of your Roomba. It is slightly more work than the front wheel, which can be found here, but is a straightforward process.
Stap 1 Side Wheel  ¶
Find the blue wheel at the bottom of the Roomba, and unscrew the three captive screws holding it in place using a Phillips #1 screwdriver. Find the blue wheel at the bottom of the Roomba, and unscrew the three captive screws holding it in place using a Phillips #1 screwdriver. Find the blue wheel at the bottom of the Roomba, and unscrew the three captive screws holding it in place using a Phillips #1 screwdriver.
Stap 1 Side Wheel  ¶
  • Find the blue wheel at the bottom of the Roomba, and unscrew the three captive screws holding it in place using a Phillips #1 screwdriver.
Stap 2  ¶
Gently lift the wheel to remove. Gently lift the wheel to remove.
Stap 2  ¶
  • Gently lift the wheel to remove.
