Help
Imation Superdisk USB Drive Daughter Board Replacement
Opsommingstekens!
Opsommingstekens!
Betere coördinatie met markeringen en kleur/type bullet points om deze handleiding nog duidelijker te maken!
Mislukte opmaak
Mislukte opmaak
Deze handleiding heeft een betere opmaak nodig. Help mee door het corrigeren van de opmaak of door aantekeningen te maken.
This guide demonstrates how to remove the daughter board.
  • Auteur: Darlena
  • Geschatte tijd: 2 minuten
  • Moeilijkheid: Eenvoudig
This guide is to help you step by step on how to replace the daughter board to the Imation Supserdisk USB drive.
Stap 1 Daughter Board  ¶
Flip the disk drive over so the the plug on the daughter board is visible.
  • Flip the disk drive over so the the plug on the daughter board is visible.
Stap 2  ¶
Using an iPod opener put pressure on the white plug and pull backwards until the daughter board unplugs from the main unit. Using an iPod opener put pressure on the white plug and pull backwards until the daughter board unplugs from the main unit.
Stap 2  ¶
  • Using an iPod opener put pressure on the white plug and pull backwards until the daughter board unplugs from the main unit.
Stap 3  ¶
Gently pull on the daughter board until it separates from the device. Gently pull on the daughter board until it separates from the device.
Stap 3  ¶
  • Gently pull on the daughter board until it separates from the device.
