Ga door naar hoofdinhoud
Help
PowerBook G4 Aluminum 17" 1-1.67 GHz Inverter and Antenna Cables Replacement
This guide will show you how to replace the inverter/antenna cables.
Stap 1 Inverter and Antenna Cables  ¶
Carefully grasp the inverter connector with the ends of your fingertips and pull it straight down. Carefully grasp the inverter connector with the ends of your fingertips and pull it straight down.
  • Carefully grasp the inverter connector with the ends of your fingertips and pull it straight down.
Stap 2  ¶
Peel the protective translucent shield off the antenna board. If you damage this during disassembly, be sure to tape over any tears or cracks to avoid unintended shorting.
Stap 2  ¶
  • Peel the protective translucent shield off the antenna board.
  • If you damage this during disassembly, be sure to tape over any tears or cracks to avoid unintended shorting.
Stap 3  ¶
Use the flat end of a spudger to pry the the antenna cables straight up off their sockets. Use the flat end of a spudger to pry the the antenna cables straight up off their sockets.
Stap 3  ¶
  • Use the flat end of a spudger to pry the the antenna cables straight up off their sockets.
Stap 4  ¶
De-route the inverter/antenna cables from the front display bezel.
Stap 4  ¶
  • De-route the inverter/antenna cables from the front display bezel.
