Ga door naar hoofdinhoud
Help
iRobot Roomba 4100 Brush Guard Replacement
Actiemomenten
Actiemomenten
Wees een actieheld! Deze handleiding heeft plaatjes nodig die beter tonen hoe specifieke handelingen uitgevoerd moeten worden.
Heeft betere plaatjes nodig
Betere foto's zullen deze handleiding verbeteren. Help mee door het nemen, bewerken of uploaden van nieuwe foto's!
This is a guide for either maintenance or removal of the brush guard in the Red Roomba 4100.
Removing the brush guard will be easy. It won't take more than 5 minutes to complete and no tools are required.
Stap 1 Brush Guard  ¶
Lay the Roomba upside down on a flat surface with the blue strip away from you.
  • Lay the Roomba upside down on a flat surface with the blue strip away from you.
Stap 2  ¶
Use your index fingers to pull the yellow tabs towards you. While still pulling the yellow tabs with your index fingers, tilt up the brush guard.
Stap 2  ¶
  • Use your index fingers to pull the yellow tabs towards you.
  • While still pulling the yellow tabs with your index fingers, tilt up the brush guard.
  • For reassembly, make sure to push in the brush guard until it clicks into place.
Stap 3  ¶
Pull back the brush guard to unhook it from the latches.
Stap 3  ¶
  • Pull back the brush guard to unhook it from the latches.
  • Remove the brush guard by lifting it up and out of the Roomba.
  • This picture has a change in orientation to illustrate the latches. Continue disassembling the Roomba with the blue strip away from you.
