Ga door naar hoofdinhoud
Help
Palm IIIx Motherboard Assembly Replacement
Mislukte opmaak
Mislukte opmaak
Deze handleiding heeft een betere opmaak nodig. Help mee door het corrigeren van de opmaak of door aantekeningen te maken.
Opsommingstekens!
Opsommingstekens!
Betere coördinatie met markeringen en kleur/type bullet points om deze handleiding nog duidelijker te maken!
Ontbrekende informatie
Er ontbreekt wat informatie aan deze handleiding. Help gebruikers door het toevoegen van gereedschappen, moeilijkheidsgraad of tijd.
How to replace a Palm IIIx motherboard.
Installing a new motherboard assembly which contains the processor and software package.
Secties
Gereedschap
Stap 1 Motherboard Assembly  ¶
Using a Phillips #00 screwdriver, remove the four screws that hold the back cover in place.
  • Using a Phillips #00 screwdriver, remove the four screws that hold the back cover in place.
Stap 2  ¶
Hold the device on its side, positioning your hands as shown.
Stap 2  ¶
  • Hold the device on its side, positioning your hands as shown.
  • Remove the back cover by pushing in with your thumbs and pulling outward with the rest of your fingers.
Stap 3  ¶
Hold the screen and front cover on its side, facing the screen inward as shown.
Stap 3  ¶
  • Hold the screen and front cover on its side, facing the screen inward as shown.
  • Position your hands so that you can push the screen outward with your thumbs.
  • Remove the screen by pushing outward with your thumbs. Use your index fingers to hold the front cover in place.
Stap 4  ¶
Position the device with the screen facing down. Locate the white ribbon wire on the left hand side of the device.
Stap 4  ¶
  • Position the device with the screen facing down.
  • Locate the white ribbon wire on the left hand side of the device.
  • On either side of the ribbon wire are two white clasps. Gently push the two clasps away from the board (to the left).
Stap 5  ¶
Detach the ribbon wire by gently pulling it out of its connector.
Stap 5  ¶
  • Detach the ribbon wire by gently pulling it out of its connector.
Stap 6  ¶
Separate the motherboard from the screen.
Stap 6  ¶
  • Separate the motherboard from the screen.
Stap 7  ¶
Now the motherboard assembly can be replaced successfully.
Stap 7  ¶
  • Now the motherboard assembly can be replaced successfully.
