Ga door naar hoofdinhoud
Help
Samsung SCH-A890 External Speaker Replacement
Onjuiste gereedschappen
Help om deze handleiding beter te maken door de juiste gereedschappen in plaatjes en/of tekst te gebruiken.
  • Auteur: Justin Fang
  • Geschatte tijd: 10 minuten
  • Moeilijkheid: Eenvoudig
This guide is a step by step process to enable you to gain access to and remove the phone's external speaker that is used for the speakerphone function.
Secties
Gereedschap
Stap 1 External Speaker  ¶
Remove both screws with a #00 philips screwdriver. Remove both screws with a #00 philips screwdriver. Remove both screws with a #00 philips screwdriver.
  • Remove both screws with a #00 philips screwdriver.
Stap 2  ¶
Once the screws are removed gently pull back the gold mount to expose the speaker. Remove the small piece of plastic that holds the wire down. Use your fingernail or a small screw driver to pry the speaker out.
Stap 2  ¶
  • Once the screws are removed gently pull back the gold mount to expose the speaker.
  • Remove the small piece of plastic that holds the wire down.
  • Use your fingernail or a small screw driver to pry the speaker out.
