Help
Power Mac G4 Quicksilver Power Supply Replacement
Gearchiveerde handleiding
Deze handleiding wordt enkel nog bijgehouden voor historische doeleinden. Gebruik de laatste versie van deze gids om uw reparatie uit te voeren.
  • Auteur: Jacob Garcia
  • Geschatte tijd: 10 - 15 minuten
  • Moeilijkheid: Gemiddeld
Removing the power supply of the Power Mac G4.
Stap 1 Power Supply  ¶
The power supply is in the upper right corner of the case.
  • The power supply is in the upper right corner of the case.
Stap 2  ¶
There is a total of four screws to be removed. The first three can be seen in the first picture.
Stap 2  ¶
  • There is a total of four screws to be removed.
  • The first three can be seen in the first picture.
  • The final screw can be seen in the second picture.
Stap 3  ¶
There are three 2.5mm hex bolts located in the back of the computer that also need to be removed.
Stap 3  ¶
  • There are three 2.5mm hex bolts located in the back of the computer that also need to be removed.
  • A 3/32" Hex Key or Hex Driver is a bit small but may also work if gentle.
Stap 4  ¶
Disconnect the power supply cables from the mother board by pressing in the tab on the back of the connector as shown.
Stap 4  ¶
  • Disconnect the power supply cables from the mother board by pressing in the tab on the back of the connector as shown.
Stap 5  ¶
Before sliding out the power supply make sure to disconnect the cable to the big fan by pressing in the small black tab on the back of the black connector!
Stap 5  ¶
  • Before sliding out the power supply make sure to disconnect the cable to the big fan by pressing in the small black tab on the back of the black connector!
  • Slide the power supply away from the back of the computer and pull it out carefully stringing the cables through the hole in the metal support.
Stap 6  ¶
Your power supply is now free from the enclosure and is ready to be replaced.
Stap 6  ¶
  • Your power supply is now free from the enclosure and is ready to be replaced.
